help with a python code
263
7
01-22-2022 01:13 AM
matu89
hey , i have the basic licence therere for i cant use Feature Vertices to Points tool.
i've found a code over the internet from this  blog:
Emil's Arc/GIS/Python: ArcGIS polygon to lines and feature vertices to points without an ArcGIS adva...
this is the code:
#feature vertices to points
import arcpy def VerticesToPoints (inFc, workspace, fcName): outFc = UniqueFileName(workspace, fcName) try: #let esri do it (advanced license) arcpy.FeatureVerticesToPoints_management (inFc, outFc) return outFc except: pass #no advanced license sr = arcpy.Describe (inFc).spatialReference outPath, outName = os.path.split (outFc) arcpy.CreateFeatureclass_management (outPath, outName, "POINT", spatial_reference = sr) with arcpy.da.InsertCursor (outFc, "SHAPE@") as iCurs: with arcpy.da.SearchCursor (inFc, "SHAPE@") as sCurs: for geom, in sCurs: for i in range (geom.partCount): part = geom.getPart (i) for pnt in part: if not pnt: continue row = (pnt,) iCurs.insertRow (row) del iCurs del sCurs return outFc
now, i tried to put my inputs in this code but it wont run..
my inputs are:
the existing polyine is called :'zpoints.shp'
and my output directory is :'c:/gis/project'
the new point layer to be created is called: 'test.shp'
where i need to write my inputs in the code?
thanks for the help!
MicZatorsky_AEC
As Luke said, you need to call the function AND you need to define the function UniqueFileName() - as this code calls it.
The code below adds a small function to do what I guess UniqueFileName() was trying to do, and shows you how to call VerticesToPoints() without having to create a script tool.
import arcpy
def UniqueFileName(workspace, fcName):
    return workspace + "\\" + fcName
def VerticesToPoints(inFc, workspace, fcName):
    try:
        return outFc
    except:
        pass
                                         outName,
                                         "POINT",
            for geom, in sCurs:
                    for pnt in part:
                        if not pnt:
                            continue
                        row = (pnt,)
    del iCurs
    del sCurs
    return outFc
inFc = "tmp_ln" # input line feature class
workspace = r"C:\temp\Scratch.gdb"  # GDB
fcName = "tmp_pt" # output point FC
Luke_Pinner
MVP Regular Contributor
It's a function. You need to call it:
VerticesToPoints ("C:/path/to/zpoints.shp", "c:/gis/project", "test.shp")
You could also research how to create a python script tool.
MicZatorsky_AEC
import arcpy
    try:
        return outFc
    except:
        pass
                                         outName,
                                         "POINT",
            for geom, in sCurs:
                    for pnt in part:
                        if not pnt:
                            continue
                        row = (pnt,)
    del iCurs
    del sCurs
    return outFc
matu89
hey,
still dont work for me:
here is the data from Arcgis Pro:
what i did wrong?
HuubZwart
The describe function fails because the path to 'zzpoints' does not exist. Note it takes it path relative to the currently active workspace: you could set the active workspace in your script before you access the feature class:
arcpy.env.workspace = r"C:\Users\sasim\Documents\ArcGIS\Projects\MyProjects\MyProject.gdb"
MicZatorsky_AEC
Exactly.  Or provide a fully qualified path to the feature class:
inFc = r"C:\Users\sasim\Documents\ArcGIS\Projects\MyProject\MyProject.gdb\zpointss" # input line feature class
matu89
thank you very much! it works !!
JoshuaBixby
@matu89, please mark some responses as accepted solution to close out this thread.
