Group Layer Templates: Share values?
144
a month ago
Labels (2)
AlfredBaldenweck
MVP Regular Contributor
I'm making a group template containing a point and a buffer polygon, buffering the point by 50 ft.
Is it possible to have this buffer polygon automatically share the value of a field in the Point, e.g. its name?
The point template, with the Name field exposed to pre-fillThe polygon template, with the Name field exposed to pre-fill
The group template, with the Name field of the point layer exposed to pre-fillThe group template, with the Name field of the polygon layer exposed to pre-fill
The group template, with the Name field of the point layer exposed and filledThe group template, with the Name field of the polygon layer exposed but not filled out
Resulting featuresThe attributes of the resulting features.
As you can see, the attributes are not linked. My question is: Is it possible to link them via a field map or something? (I know we could probably accomplish this with attribute rules but I'm looking for a native solution because I feel it's an obvious need: If I buffer a point I expect there to be some sort of link between the two. so I know why it's there.
