Graduated Colors Out of Range
89
12-02-2021 07:04 AM
RichardCarter
New Contributor II
I have a feature class I am trying to symbolize using graduated colors. The data is grouped by manual interval using "year" field to show when a lot was developed. When I turn off the "show values out of range" option about half of the features disappear. There are no null values in the dataset."out of range" = on"out of range" = on"out of range" = off"out of range" = off
DanPatterson
MVP Esteemed Contributor
curious... do you have any dates beyond 2018?
it seems to be affecting everything since your color scheme doesn't even match what is on screen
... sort of retired...
RichardCarter
New Contributor II
2018 is the latest date. The colors on the map are custom colors so I am not using a pre-defined color scheme. Anyway, I can use any color scheme I want and still get the same results.
