GP tool to select greatest 1 per group
587
12-06-2022 08:09 AM
Bud
Notable Contributor
Is there an OOTB geoprocessing tool that can be used to select the greatest 1 per group in a FGDB table?
For example, for a given ASSET_ID, select the road inspection that has the latest date.
Related:
Robert_LeClair
Esri Notable Contributor
I know you mentioned you're using a fGDB but if you were using an enterprise gdb (egdb), then you could use SQL to do this.
There's an article here that explains the syntax to use - <date> = (SELECT MAX(date) FROM <table_name> GROUP BY <group_ID>)
The article does say if you create an OLE DB connection to a MS Access table then you could use the SQL syntax above.
Looking for a fGDB solution right now.
UPDATE:  It seems with Python you can do this - here's a link here that shows a labeling example.  I'm not a Python person but I suspect many on this forum are.
UPDATE 2:  For fGDB data, use the Dissolve GP tool with the Maximum value set for the Statistics Field Parameter.  That should work for you BUT it does create a new FC unfortunately.
Bud
Notable Contributor
Thanks!
FYI - The SQL syntax in that article appears to be incorrect: Select maximum values in Select By Attributes (greatest n per group)
Also, for my notes, the Dissolve tool doesn't seem to work for standalone tables. But the Summary Statistics tool does.
