GetUser - need only user name
255
07-29-2021 08:59 AM
Labels (2)
LukeGilner1
I'm trying to get the currently logged in username in an Arcade expression in ArcPro 2.8.  I've used the GetUser(Portal('https://www.arcgis.com')) to populate the user id, username, name, email etc. in a big long string, but I only want the username.  How can I do that?  Seems like it should be fairly straight forward.
2 Solutions
LukeGilner1
I've figured this out using a combination of GetUser, Mid, and Split functions.  The GetUser returns the long string of id, username, name, email, etc., so I used the Mid function to separate a portion of it, where the username begins.  Since our all of our users usernames are different lengths but have a "@" symbol in them, I was able to use the Split function to split it by the "@", which returns an array, so then I called to return the first part of the split array (array[0]).  I only need this first part in my data.  See below for what I entered in the calculate field tool.  I'm sure there's an easier way to do this.
var userinfo = Mid(GetUser(Portal('https://www.arcgis.com')),53,20);
var array = Split(userinfo,"@",1);
var username = array[0];
return username;
Spacelord
I guess there is a slightly more elegant way. I searched the web for hours und struggled with my own fiddly solution until I found this video. Try this. I think it will work with every other entry in the dictionary list:
var p = Portal('https://www.arcgis.com');
var u = getUser(p);
var fullName = u.fullName;
return fullName;
ScottLehto3
I am wondering how to do this in C# using the Pro SDK.
LukeGilner1
return username;
Spacelord
var u = getUser(p);
return fullName;
LukeGilner1
YES - THANK YOU!
I knew there had to be an easier way to get the specific items from the dictionary list.  I too stumbled upon that video after hours of web searching, but it seemed like I needed to identify the specific users so it wouldn't work for me.
I modified your code slightly to grab the username, and I also still needed to use the split function because I only wanted the first part of the username.  Thanks again!  I get discouraged when I don't receive responses from the community.
var u = getUser(p);
var fullusername = u.username;
var array = Split(fullusername,"@",1);
return username;
