Generate Net CDF from Point Dataset for Animation on ArcOnline
160
02-22-2024 08:57 AM
Labels (2)
TomWingrave
Hello,
I have been tasked with generating some animated water flow lines for a project I am working on. I've generated a series of Points with a flow direction, magnitude and date field on them and I am attempting to convert them to a Net CDF file, however, the outputs I produce are blank.
Here's an example of the point data I have generated;
Flow direction is the direction that the original flow line was orientated in and then the mag/date fields are ones that I have generated to allow the generation of the Net CDF. I have basically cloned each point 3 times and assigned differing mag and date/time values.
The parameters I have set for the tool are as follows and the direction/magnitude fields are both float fields. The Date field is a time/date field.
The tool runs but the output is blank when I add it in using add multi dimensional raster - am I missing something really obvious. I have scoured the guidance but cannot see anything.
Tom
