Hi all, I am trying to get field calculator to help me extract a string from a field and calculate in another field.
Name | Info |
ABCDEFG_(0.2014HA) | !Place!.split('(')[1].split(')')[0] |
ABCDEFG (TESTXX) (123HA) | ?? |
So for the first field the calculation will get me the value in brackets so I end up with 0.2014HA which is great.
How would I do it for the second one? I want to extract only what is in the second bracket and ignore the first one
Thanks a lot in advance!
Solved! Go to Solution.
a = 'ABCDEFG_(0.2014HA)'
b = 'ABCDEFG (TESTXX) (123HA)'
a[a.find("("):].split(" ")[-1][1:-1]
'0.2014HA'
b[b.find("("):].split(" ")[-1][1:-1]
'123HA'
# ---- yielding a code block for your 'fld'
def splitter(fld):
"""Split on a unique case"""
val = fld[fld.find("("):].split(" ")[-1][1:-1]
return val
splitter(a)
'0.2014HA'
splitter(b)
'123HA'
morning brain refresher
I found another way of doing it too.
!Name!.split('(')[2].split(')')[0]
'0.2014HA'
'123HA'
def splitter(fld):
return val
splitter(a)
'0.2014HA'
splitter(b)
'123HA'
True, but yours fails for the first case
a.split('(')[2].split(')')[0]
Cell In[3], line 1
IndexError: list index out of range
b.split('(')[2].split(')')[0]
'123HA'
where as the function in my example works for both
