Exporting feature fails to include all fields
230
a month ago
MichaelSeymour
I just upgraded to ArcGIS Pro 3.3.0.
I'm running into an issue exporting features using the typical right click on feature in Contents --> Data--> Export Features. Previously, the output feature would include all the fields from the source feature, but now I'm getting a random assortment of fields that don't include all fields but *do* include previously deleted fields from the source feature...
My workaround is bringing the source feature into ArcMap and exporting the feature that way. It works fine in ArcMap...
Any ideas?
Thanks!
Michael Seymour
mseymour at wlf.la.gov
DanPatterson
BUG-000154896 for ArcGIS Pro (esri.com)
apparently, but I don't use your shorcut, but the Featureclass to Featureclass tool (which they recommended as a 'workaround' for some strange reason, instead of the first tool to use)
... sort of retired...
DanPatterson
sounds familiar
Solved: Pro not exporting all fields of hosted feature lay... - Esri Community
see if this matches your case
MichaelSeymour
Thanks for the quick reply! Yep, I saw that post, too, but it sounded like the bug had been fixed, no?
DanPatterson
MichaelSeymour
Yep! That seems to work! Thank you! I really appreciate the assistance!
