Error 002809 Field OID unsupported in shapefile export
1371
7
11-28-2023 09:29 PM
Labels (3)
AndrewFletcherWTS
I am using ArcGIS Pro 3.2 and have come across the Error 002809: FIeld OID in XXX is of an unsupported type for the output workspace. I have not been able to find this error in ESRI resources or community chat. It seems like an obvious problem that should not exist given the limited options for export from the geodatabase in Catalog. The geodatabase requires the OID and fails to export as FID or appropriate for shapefile. Any ideas gratefully appreciated.Screenshot 2023-11-29 152147.png
AndrewFletcherWTS
Work around, use Geoprocessing Feature Class to Shapefile tool, right clicking and selecting Export to Shapefile in the Catalog is fraught.
DanPatterson
Try Copy Features (Data Management)—ArcGIS Pro | Documentation
from ArcToolbox
... sort of retired...
MadanThapaChhetri
I tried this but did not work when I tried to export the shapefile to different folder connections.
SIGMOSELLEAVAL
Same problem here...
I have tried the first work around with success.
SThor1
I am getting this error too. I was not able to resolve using Feature Class to Shapefile. I have a join on my layer that I want to export as a standalone SHP. Keep getting this error. Must have something to do with the new field type "Big Integer" because that is the only one giving me grief here.
Edit: My work around was to delete the "Big Integer field" in my target layer. Not really ideal but got me past the hurdle
MadanThapaChhetri
The same things worked previously, but now, when I try to export, copy, or clip and make the output layer in a folder other than the working geodatabase, I face problems like yours.
ERROR 002809: Field acq_date in delta is of an unsupported type for the output workspace.
MadanThapaChhetri
You can add new fields and calculate field operations for added fields, then delete the previous field that hinders your process and try to export it. It will help you to do that.
