I am trying to give users privileges in Pro and cannot add them so some layers without getting a check constraint violation. I can't open the properties for the specific layer in the Group Layer giving me the error either. I can't seem to find any documentation on this.
Hmmm...I would start by running the Diagnose Version Table (Data Management ) GP tool to see if there are any issues with the versioning system tables (A & D's) first. Based upon that, we can start digging deeper....
How do I get to the tables log?
So the Diagnose Versions Tables Log is an ASCII file that is the output from the tool. You decide where the output should be written to - say C:\temp for example.
Ahhhh...the dreaded 999999 errror code! Instead of writing the log file to your U: drive can you write it to your C: drive instead? Does it error out again?
Sure does
Okay - I think I see what's happening in your screen shot. You're missing the Target Version parameter. See attached below for my GP tool. It worked as expected.
Still fails
Okay - when I see strange things like this, one thing I do is rename the ESRI folder to ESRI_OLD. There are two ESRI folders to rename. One is in your C:\Users\<your_user_profile>\appdata\local and C:\Users\<your_user_profile>\appdata\roaming. Close ArcGIS Pro, rename the folders, restart and load your *.aprx and try the GP tool again. What is the result? Also are you using your SDE (GDB Administrator) for the input database connection parameter?
