Check constraint violation
367
13
01-26-2023 09:35 AM
Laura
New Contributor III
I am trying to give users privileges in Pro and cannot add them so some layers without getting a check constraint violation. I can't open the properties for the specific layer in the Group Layer giving me the error either. I can't seem to find any documentation on this.
Robert_LeClair
Esri Notable Contributor
Hmmm...I would start by running the Diagnose Version Table (Data Management ) GP tool to see if there are any issues with the versioning system tables (A & D's) first.  Based upon that, we can start digging deeper....
Laura
New Contributor III
How do I get to the tables log?
Robert_LeClair
So the Diagnose Versions Tables Log is an ASCII file that is the output from the tool.  You decide where the output should be written to - say C:\temp for example.
Laura
New Contributor III
Robert_LeClair
Ahhhh...the dreaded 999999 errror code!  Instead of writing the log file to your U: drive can you write it to your C: drive instead?  Does it error out again?
Laura
New Contributor III
Sure does
Robert_LeClair
Okay - I think I see what's happening in your screen shot.  You're missing the Target Version parameter.  See attached below for my GP tool.  It worked as expected.
Laura
New Contributor III
Still fails
Robert_LeClair
Okay - when I see strange things like this, one thing I do is rename the ESRI folder to ESRI_OLD.  There are two ESRI folders to rename.  One is in your C:\Users\<your_user_profile>\appdata\local and C:\Users\<your_user_profile>\appdata\roaming.  Close ArcGIS Pro, rename the folders, restart and load your *.aprx and try the GP tool again.  What is the result?  Also are you using your SDE (GDB Administrator) for the input database connection parameter?
