cartographic representation in ArcGIS Pro
193
10-18-2021 02:00 AM
Moelsaket
Dears, I'm use ArcGIS Pro 2.8.3 does this version support cartographic representation or not?
and if not what is the alternative features that i can use in ArcGIS Pro.
DanPatterson
You mean something more than this?
, ArcGIS defines a layer as a cartographic representation of data
and
Draw layers with representations—ArcGIS Pro | Documentation
... sort of retired...
Moelsaket
no, I want to create cartographic representation in ArcGIS Pro and modify it, same thing as ArcMap after some search I find out that it's not supported so I want another solution same as cartographic representation.
MichaelVolz
Dan:
Does your proposed solution imply that ArcMap must be used in conjunction with Pro?
