ArcGIS Pro Slope Tool failing with Output measurement and Z factor parameter in C#
185
a month ago
Shahadat_1200
The code below with parameters in 14th line fails to run slope tool and get expected result
 public SlopeTool(string inRaster, string outRasterName, string workspace, string prjFilePath)
     _inRaster = inRaster;
     _outRasterName = outRasterName;
     _workspace = workspace;
     _prjFilePath = prjFilePath;
 public async Task<IGpResult> ExecuteAsync()
     try
         var slopeToolParameters = Geoprocessing.MakeValueArray(
             _inRaster, "PERCENT_RISE", 1
         var gpResult = await Geoprocessing.ExecuteToolAsync("sa.Slope", slopeToolParameters);
         if (gpResult.IsFailed)
             MessageBox.Show("Tool Failed");
         return new GpResult(gpResult);
     catch (Exception ex)
         MessageBox.Show($@"Error during Slope Tool operation: {ex.Message}");
         return new GpResult(null);
But this code below runs and succeeds with the parameter in 14th line
     try
             _inRaster
I can also run it in Arcgis pro python command line this way
arcpy.sa.Slope('DEM_AB_Clip1.tif', 'PERCENT_RISE', 1)
What is the problem in my 1st code and how to get expected result ?
