Altering Legend Symbology
321
03-22-2023 03:38 AM
HarryBell
New Contributor II
Hi, does anyone know if it is possible to alter the symbology of a layer item (not by altering the layer style itself)?
I have a line layer that I am displaying as quite thick dotted line on the map, but in the legend it looks bad.
So, in the legend I'd like it to appear as a nice dotted line.
Many thanks,
Harry
DuncanHornby
MVP Notable Contributor
What does it look like on the map, we have nothing to compare it with, so to me what you show is ok?
HarryBell
New Contributor II
Hi Duncan
It looks like (Grey dotted):
I have found a workaround - create a new group, copy the layer into it, and rename, calling it '2' at the end.  Style it up so it looks right in the legend.  Make it not visible on the map.
Go to Legend Properties > Synchronise with Map > Layer Visibility - turn off.
Go back to the legend in the contents pane and move the layer suffixed '2' to below the 'real' layer.  Untick the 'real' layer in the legend so it doesn't show.  Make sure the '2' layer is showing, and once all is ok, just remove the '2' for the layer in the new group you created so the label in the legend is correct.  Clumsy but it works:
