I am trying to customize my database to include better quality control. There are some fields that I never want null. So, I go to "field design" and attempt to unselect the "Allow NULL" option in the fields I would like to never have blank, but they are all "grayed out" and I cannot change them. See the screen shot below:
Any ideas how I can fix this issue?
Is your database a file geodatabase by chance? My guess is this is not availabe in the file geodatabase format. If you are using a RDBMS such as SQL Server, you can use SQL Server Management Studio to set a "not null constraint" on an attribute field.
In SQL, it would be:
alter table <owner>.<feature class>
alter column <column name> int not null
Hope this helps!
If the gdb contains data, it can't be changed
Modify field properties—ArcGIS Pro | Documentation
Hope this helps!
This worked. Thank you.
