Selection Layer should persist when copied/dragged between instances of ArcGIS Pro
547
06-27-2022 07:15 AM
Status: Implemented
RichardHowe
Occasional Contributor III
As per my post here:
https://community.esri.com/t5/arcgis-pro-questions/selection-layer-does-not-persist-between-projects...
(acknowledged by ESRI staff)...
Currently when you drag and drop or copy and paste a selection layer between instances of ArcGIS Pro it does not honour the selection and instead reverts to showing the whole layer,. This is a change in behaviour from ArcMap and something that would be good to see reintroduced as all other layer properties are retained e.g. symbology/definition queries etc.
3 Comments
CraigWilliams
wayfaringrob
Right now when dragging a selection layer from one project to another, it loses its selection in the process. This is despite a false/misleading warning that you're working with a selection layer:
This can lead to many, many problems, especially when the user may be unaware that they're working with a selection layer in the first place -- there is no warning that the selection has been turned off, and in many scenarios, this may not be noticed. Such a situation could also be avoided or at least mitigated by filter indicators in the TOC.
Please allow the selection to persist when dragging and dropping into another project. Thanks.
KoryKramer
This issue was addressed in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
