When copying a map in Pro, have the copied map maintain all of the Grid Settings that are present in the original map. Currently, when copying a map that has Grid Settings (i.e. Disabling Dynamic Scaling and View Extents), the copied map has a grid present, but Dynamic Scaling will be re-enabled and View Extents will be added if they were removed before.
