Optional setting to disable Z-values by default
862
06-16-2022 05:18 PM
Status: Open
Bud
Esteemed Contributor
When creating a new feature class in Catalog, Z Values is enabled by default.
None of our data is 3d, so we uncheck that Z box for each feature class we create.
In my opinion, that checkbox should be disabled by default, since I would think organizations have more 2d FCs than 3d FCs. It might seem like a small thing, but I actually create new FCs many times per day — as part of testing and development work. So, unchecking that box becomes a bit of an annoyance.
Could Esri consider disabling that checkbox by default? Or give us an optional setting somewhere to change that behavior?
3 Comments
DanPatterson
ArcToolbox as well?
Bud
@DanPatterson As you mentioned, Z-values aren't enabled in the ArcToolbox GP tool, so that's good.
I find it easier to use the Catalog method...but good to be reminded of the GP tool too.
DanPatterson
And there is no option in the project backstage to standardize the behaviour of "create featureclass" in geodatabases.
That shouldn't be the case, so given the differences between the access points to fc creation, perhaps that is the thing that should be "fixed" 😉
