Legend: Only show classes from this heading
890
11
11-09-2021 03:20 AM
Status: In Product Plan
IlkaIllers1
Occasional Contributor III
Can we have the "Only show classes from this heading" feature that was available in ArcMap back?
11 Comments
TedCronin
Currently in Pro, I need to go to the More menu, to turn off the All other values, or go to symbology and remove there manually, but what about a setting in the legend properties to turn this capability off,  I want this capability to be more intuitive.
LyonMNGIS
I suppose for the time you could copy the layer.  On the original layer remove <all other values> so it only displays the classes you would like to see.  On the second layer include all the other values.  Then you could exclude this second layer from the legend?
It seems like a tacky workaround but it might work?
AubriKinghorn
HelenCooper
I really miss this feature too!  I know there are workarounds but this was much more elegant!
StevenSchultz
I really miss this feature. It would be nice to control either in the Format Legend Item or in the layer's Symbology. My utilities show as variations of colored lines (e.g. larger pipes shown with larger lines, forced mains include arrows) but I would like my legend to show one colored line with one label (e.g. green for waste water).
JackLau
The option exists in ArcGis Desktop for the legend option to only show classes from heading, please add this to Pro.
AmeliaBradshaw
Hello @JackLau I merged the Idea you just posted with this existing Idea, since they covered the same topic. Please add your vote using the Kudos button above!
Thank you!
DanaNolan
This is slowing down converting to Pro. I used this option in ArcMap when I had layers with very similar unique symbols and when I use Symbol Levels, which requires using unique symbols to work. I have dozens of maps and layers with a heading "Show" to pick what is shown in the legend.
AubriKinghorn
MillenniaOne
@AubriKinghorn  - any idea when this option will be available again?
