For example, you have a polyline layer with a sewer pipe and a point layer with a manhole. You want to be able to draw a polyline of a pipe with a manhole at the end, or at the beginning and end, or manholes at a certain interval in meters in one operation.
Check out group templates: Create a group template—ArcGIS Pro | Documentation
The only issue is that there currently isn't any way to have them share attributes unless you use attribute rules.
I use the snapping tool to snap my polylines to points.
In our case, the manholes have been gps'ed, so I know drawing in sewer or water lines from one hand hole or manhole to another opening in the line is accurate.
Hope that helps.
I vectorize utility networks using raster data from topographic and geodetic surveys by comparing the actual location of manhole covers on a high-resolution orthophoto. I've seen a similar drawing function in AutoCAD and would like to implement it in ArcGIS as my main software.
@FedirBalaba Like @AlfredBaldenweck mentioned, you can already do this with Group Templates.
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-a-group-template.htm
Here is how to create a basic one - but they can get more complex by adding multiple builders:
They also work with a Utility Network:
