Attribute Table — Row header context menu option to open Modify Features pane
213
11-29-2023 11:15 PM
Status: Open
Bud
Notable Contributor
ArcGIS Pro 3.2; Mobile Geodatabase feature class:
Scenario:
I'm reviewing features in the Attribute Table. I see a feature that requires a geometry edit. Currently, I would need to manually open the Modify Features pane, which may or may not be already open in the background in the panes window. Or, I could zoom to the feature, choose the select tool, and right-click the feature to get the Edit Vertices option.
I wonder if it would be easier to simply right-click the row header in the Attribute Table and click a "Modify Features" option.
1 Comment
KoryKramer
You can use Ctrl+Shift+M to open the Modify Features pane, or customize that shortcut to something shorter/easier for you to remember:
