If I make a simple symbology change, such as changing the symbol font size, it takes 13 seconds to for ArcGIS Pro to make the change.
("Swamp" symbol)
13 seconds is too long. A simple setting change like that should happen instantly. Especially since the map display is paused.
For reference, ArcMap symbology changes happened instantly.
Could the performance be improved? Thanks.
ArcGIS Pro 3.0.2
I wonder if this is somehow linked to an issue I have as discussed here?
