Kindly, gray out (disable editing) system related fields that do not require user input. For example, Validation Status is grayed out, but Retire Parcel Count is not.
Also, is there a way to group similar or reorder fields.
Thank you.
The Create Record pane inherits the settings of your record layer.
Steps:
The reason we have left the 'Created Parcel Count' and 'Retired Parcel Count' editable is that there are some (not common) use cases for manually editing them. You can easily mark them as 'Read Only'.
Does this meet your requirements?
