When entering a traverse you can do most things without entering an exception code, see my other idea for curve entry parameters, which means that when entering a traverse you can do the entire data entry with only the number pad (ten key pad). Could you please add a way to reverse a bearing without having to do it as a mouse click like what was in ArcGIS Desktop? Since this feature seems to be completely gone now at a minimum at least add back in the Reverse Bearing option as a mouse click.
Thanks Sean. I've added it to our product plan.
Any idea/preference on which key on the number keypad to use to flip a direction?
And yes - there should be also an explicit contextual menu using the mouse.
I am using this (https://pro.arcgis.com/en/pro-app/help/editing/enter-a-traverse.htm) page as reference to what shortcuts are already in use and it looks like there is already quite a few in the list. I think the best one left would be using a double negative (--) but I am very open to other options I would just like the feature included.
Hello @SeanLyons
I'm happy to inform that this request has been implemented in ArcGIS Pro 3.2!
Implemented with ArcGIS Pro 3.2
