When I edit a table in arcgis pro, is the change permanent?
501
02-06-2023 06:25 AM
LAWRENCESUTTLE
I'm about to edit a table with 1,000 records in arcgis pro before I apply Geocode Table. I was wondering if the original table in the project folder will be changed too.Thank you.
ShanaBritt
@LAWRENCESUTTLE Are you asking if the table of 1,000 records will be modified when used as input to Geocode Table or editing before using the table in the tool?
LAWRENCESUTTLE
Hi Shana, I usually edit after using the Geocode Table tool.
ShanaBritt
@LAWRENCESUTTLE If you edit the result of using Geocode Table, such as using the Rematch Addresses pane the changes will be reflected in the result and not the original input table. Are you editing the result of Geocode Table or are you editing the input table that is being geocoded?
https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/what-is-included-in-the-geocoded-result...
