Trouble with Google Sheets - Looking for alternative solution?
126
Wednesday
KateSweet
I have a Google sheet that a team of people contributes to that I want to update on a field map throughout a field season. I tried uploading the Google sheet in AGOL and saw this message. I tried adjusting security settings as well as using a non-work email address to host the file and transfer it over, but still no success. Does this feature still work for you? Is there a specific email/security setting that I've missed?
Is there another workaround to do something similar (update a layer throughout a season with a linked Google sheet)?
ScottB
by Esri Regular Contributor
Hi - this is something the ArcGIS Online team is aware of. If you log a support case you will be attached to the issue and will be notified when the team finds / implements a solution.
Also, in lieu of using Google Sheets you could potentially set up a Survey123 survey connected to a hosted feature layer to ingest information from contributors directly into ArcGIS.
ScottB
