ESRI - please turn off the time slider. Who wants their initial data view limited by a time slider?
Solved! Go to Solution.
If you are referring to the time slider of a web map, it can be disabled/hidden by the map owner. If the map is saved with the time slider hidden it will not show up when you open the map.
