Symbolise colours and amounts (size) - max value
68
08-19-2022 03:44 AM
AndrewCampbell-Sutton
I should be able to update the maximum value in the data range being used to symbolise a point layer using the colours and amounts (size) method (manual interval), right?
Because unless I'm being dense - perfectly possible - I can't.
I'm using the new map viewer symbolising with an integer field. I can change the method (e.g. from manual to jenks and back) and the upper value will update. The problem is my upper value will increase each day.
I'm using the symbolise values out of range option as a workaround
Tags (3)
