String to Numeric Calculations
446
09-28-2022 07:27 AM
Labels (2)
OznurGeze
New Contributor III
Hello Everyone,
I have a string field that contains digits, for example "7-8", and I want to calculate it to new numeric field (double) as average "(7+8)/2" of the string value. Is it possible? The dash between integers seem to cause the problem.  Do you have any idea If It could be done?
Best wishes,
Öznur
JohannesLindner
MVP Frequent Contributor
With Arcade:
return Average(Split($feature.TextField, "-", -1, true))
Have a great day!
Johannes
OznurGeze
New Contributor III
Hi, I could try it in ArcGIS pro but not AGOL, because it says;
Thank you anyway 😞
Have a great day, too 🙂
jcarlson
MVP Esteemed Contributor
It won't be pretty, but using AGOL's subset of allowable SQL functions, you can try something like this:
((SUBSTRING(str_field, 1, (CHAR_LENGTH(str_field) - POSITION('-', str_field)))) + (SUBSTRING(str_field, (POSITION('-', str_field) + 1), 100))) / 2
I don't have an AGOL layer to fully test this on, but here's a DB Fiddle that's pretty close, though the POSITION function follows a different syntax:
https://www.db-fiddle.com/f/bJkJyB5dy4jNvVA5Qz6aHo/0
- Josh Carlson
Kendall County GIS
