Setting or clipping map service to an area of interest
770
09-29-2022 01:07 AM
burwelbo
I am trying to use some Living Atlas services in some applications. I would like to be able to set an area of interest and if possible clip a certain area so that users can only view that AOI. Is there a way so that users cannot pan out of a certain extents?
Thanks
Bruce Burwell
Corey_M
Hi @burwelbo
You can set the AOI if the layers are saved in a web map, you can then access the settings of the web map and edit the extent to the desired location.
You have a few options to set the extent when in the edit/set extent options outlined here - Configure map—ArcGIS Online Help | Documentation
I have included a screenshot of the UI below with the options on the left panel:
UI.pngThere is a way to set the limit for zoom-out extent for a hosted feature service by setting the visible scale range in ArcGIS Online. This allows you to determine and change the scale at which a layer in your map is displayed, but this will not prevent the user from being able to pan or zoom in and out on the Web map.
Corey
RussRoberts
Esri Notable Contributor
Blend modes in Map Viewer and use a 4.x web app like Experience Builder, Dashboards or Instant Apps.
BruceBurwell1
New Contributor III
Both of these look like good solutions.
BruceBurwell1
New Contributor III
Is it also possible to set up queries on Living Atlas data for just the data that falls within your defined area of interest?
