Is it possible to use a hosted feature layer from Portal in an AGOL notebook?
244
06-14-2024 06:46 AM
GregKeith
Occasional Contributor III
Is it possible, and if so how, to use a hosted feature layer from our Enterprise Portal in an AGOL notebook? We don't have the Notebook Server Extension for Portal, so hoping to run a simple script from AGOL. Thanks!
jcarlson
MVP Esteemed Contributor
Absolutely! We used to do that for nightly scripts. All you have to do is connect to your Portal in the notebook.
from arcgis.gis import GIS
gis = GIS('your portal url', 'user', 'password')
# do your stuff here
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
GregKeith
Thanks @jcarlson !
jcarlson
Of course!
I know you didn't ask about this, but some advice: if you're using the AGOL notebook env, you may run into situations where you really need some other module that's not part of the default environment. If that happens, don't forget about throwing terminal commands into a cell with a "!" prefix.
If it's a small one-off, you can have the notebook install modules ad-hoc.
import sys
!{sys.executable} -m pip install some_other_module
- Josh Carlson
Kendall County GIS
