How can I change the size of clustered features?
888
10
01-24-2022 11:39 PM
barrylim
New Contributor III
Hello I created a webmap in ArcGIS Pro and shared it with ArcGIS Online. I clustered the symbols of my features, but now they are really small after zooming in. Even with the maximum Symbol Size they are a way to small.
Does someone know how to change it?
Thx in advance.
First picture is before zooming in (symbols big enough)
Second is after zooming in (symbols too small)
RussRoberts
Esri Notable Contributor
In the New Map Viewer you can adjust the sizing of the clusters using the size slider. You can see the clusters have the cluster number present and the none clustered features have no number present.
RussRoberts
DickieRigdon
New Contributor III
Hi @RussRoberts , is there a way to adjust the cluster symbol sizes in Classic Version with Arcade?  We have to use Classic for web map app publishing and not Map Viewer.  I'm trying to make the single symbol larger.  Thanks.
RussRoberts
unfortunately no. Also with Map Viewer we are planning on supporting a cluster symbol that is different from the feature symbol for a release later this year.
DickieRigdon
New Contributor III
Understood, thank you.
barrylim
New Contributor III
Thank you it worked, but now it doesn't zoom in smoothly anymore, its actually really laggy. Does this mean I have to use caching?
RussRoberts
Hard to say without looking at the map.
barrylim
New Contributor III
RussRoberts
looks good, I don't see any lagging.
barrylim
New Contributor III
Hm weird... know it works. Thank you for your help!
Have a good week 🙂
