Formatted labels will not retain setting in Map Service.
264
11-30-2023 07:38 AM
ChetShuler
New Contributor III
I like to use a narrow text setting for parcel information. A create the layer in AGOL then to My Map. The narrow setting might be retained for a couple different views after panning. Then it will suddenly revert to Normal or bold setting.. 2320 Longfellow is easier to see. I create the settings in Pro then publish.. the images do not reflect the issue as much I would like. but there is quite a difference when using the viewer. labeling5.PNGlabeling6.PNG
ChetShuler
New Contributor III
labeling9-120623.PNGDoing it again..
ChetShuler
New Contributor III
I re created the map service and layers.. Work for a couple days. Not it's doing it again..
