Filter Feature Layer for null values
1181
6
06-29-2022 08:52 AM
sgambrel_Bouldercounty
New Contributor III
Looking to filter a Feature Layer to show only features with null / no data values from a text field, but cannot figure out how to do so.
Basically trying to create a map that will be used by a field editor, showing them which features need to have data entered.  Once they add a value to the field, it will then disappear from the map.  This should be easy, right?
DataOfficer
Occasional Contributor III
In the 'is' dropdown in the middle, there should be an 'is blank' option.
DarrellHill
If I'm understanding you correctly, and if it's SQL based, your definition query should be;
<DATAFIELD> IS NULL
Can't use <DATAFIELD> = NULL
New Contributor III
I'm using the Classic Map Viewer, so IS is the only applicable operator.  I tried every combination of NULL, <NULL>, etc. and unfortunately that doesn't work.
DataOfficer
Two options if you are wanting to filter within the map, or filter the entire layer itself through a View. If you go the 'view' route, this link is also useful: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/introducing-the-new-create-and-updat...
In both instances, the filter expression will be something like 'FieldName' 'is blank'.
New Contributor III
I would like to filter in the map - how would I do so?
A View might work but is unnecessarily cumbersome.
DataOfficer
New Contributor III
A ha!  That worked!  Thanks, I did not see the "Is Blank" down the list - I really figured that "Is" was going to be the operator.  Thank you.
