Feature layer change log - how to view previous versions / history
203
05-16-2024 10:05 PM
jakubk
I'm testing the change log option for hosted feature layers but I don't think i'm using it properly so after some advice
Change tracking in a database should tell me 5 things
what was changed
who changed it
when they changed it
how it was changed (before/after)
but i'm not able to get all this info out of arc online - it just gives me the changed/current version without specifying which field was changed or what it was originally
How do i use the extractChanges api call so I can answer "what changes did this person make?"
I've done some other testing like trying to use the fieldsToCompare (didn't work - returned data even when comparing on fields i didn't change)
and changing the same field back and forth between 2 different values - it didn't capture any of the intermediate changes either.. just returns the current value.. what's the point of that?
My process:
I've uploaded/published a test fgdb to a hosted feature layer. I've turned on editing and change tracking
I modify one of the fields in an attribute table
followed this guide - How To: Extract Changes from the Change Tracking Table (esri.com) & api reference - Extract Changes (Feature Service)—ArcGIS REST APIs | ArcGIS Developers
(i just put in the layerIDs i was interested in and the minServerGen and serverGen I pulled out from the metadata call - left everything else default)
I'm able to make the rest call and get a json output and yes, it has the 'row' i modified, but it only shows the current/changed version. There's no corresponding record of the original
I also tried by running the call using a minServerGen of 0 and serverGen 999999 to make sure it would grab any/all versions
Surely agol keeps the original version, otherwise how would it know what's changed
I also tried using the fieldsToCompare option but the api returned the row even when i set it to compare a field i didn't change
PhilippNagel1
Were you able to get anywhere with this? I am running into the same issue.
