I am trying to implement ARC GIS maps with Ordnance survey base map by calling API using API key. I am calling the Ordnance survey API throw WMTSLayer function. However I get error as below:
4.31/:132 [esri.layers.WMTSLayer] #load() Failed to load layer (title: 'Layer', id:
Would like to know what is causing this error.
Below is the code I am testing.
Hey Vani,
For this since there is a key within the WMTS you won't be able to put this in with the WTMS URL request, instead you will need to add the key as a Custom Parameter.
For example
const wmtsLayer = new WMTSLayer({
url: "https://api.os.uk/maps/raster/v1/wmts",
customParameters: {
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
activeLayer: "OS Outdoor 27700",
tileMatrixSet: "BritishNationalGrid",
spatialReference: {
wkid: 27700 // EPSG:27700
I would also check the URL you are using for the WMTS.
Hope that helps!
David
