Determining "is hosted feature service" vs "View Layer" using the python API for ArcGIS
146
3 weeks ago
rob_hewy
When you run an item report there is a column called "is hosted feature service".
I want to get the same info but using the ArcGIS Python API.
Any ideas?
I am also looking for a property that might inform me that a a Feature layer is a View layer versus the hosted feature service supporting the view layer.
I would also love the view layer to be a filter in the content area too.
All the best,
Rob
DavidPike
MVP Frequent Contributor
There appears to be an identifier in the Item property typeKeywords - 'View Service'
from arcgis.gis import GIS
gis = GIS("home")
#replace with your layer id
feature_id='73fdbf4gxxxxxxxxxxxx'
item = gis.content.get(feature_id)
#item property 'typeKeywords' produces a list which
#should have a 'View Service' element listed if so
print(item.typeKeywords)
#if it is a view service - print typeKewords properties
if "View Service" in str(item.typeKeywords):
  print(str(item.typeKeywords))
DavidPike
gis = GIS("home")
rob_hewy
Just wanted to add a little more for others:
Solving for hosted could be done via the typeKeywords too (see the last item in the list):
['ArcGIS Server', 'Data', 'Feature Access', 'Feature Service', 'Metadata', 'Multilayer', 'Service', 'Hosted Service']
 The feature layers I am currently investigating do not say 'View Service', instead they say 'ArcGIS API for JavaScript'
 ['ArcGIS API for JavaScript', 'ArcGIS Server', 'Data', 'Feature Access', 'Feature Service', 'Service', 'Singlelayer']
Both of the above eventually make it back to the same hosted service in our portal.
Although, I thought the SingleLayer might be a view layer this may not be the case; the later may have been made via Content => New Item => URL.
DavidPike
Ah that's useful info.  I'll also add that the view I checked returns both 'Hosted Service' and 'View Service' in the list - so may need additional checks such as if 'Hosted Service' in list and 'View Service' not in list etc. Could be other gotchas to be aware of also.
