Copying record from ArcGIS Online table
87
08-12-2022 11:12 AM
CarlNettleton
We have a community-based web map with contributions from citizen scientists. Occasionally we will receive information that a data point is inaccurate and should be removed. Before removing it, I would like to be able to copy the record and paste it into an Excel file to keep a history of those changes. I can't see how to do that. Thanks! You can see the map here
Robertc13
you can export the entire layer out to CSV or Excel by going to the Content tab, selecting the layer you want, and then clicking on Export Data button and selecting your export format.  this would export the entire layer.
In Map Viewer Classic you can export a single feature by using Extract.  open the table for a layer then highlight the row you want.  click on the Analysis button then Manage Data then Extract Data.  fill in the options as required to choose the output format, etc.
