Calculate length of line intersecting polygon
231
06-19-2024 04:40 PM
JChilders
Hey y'all,
I am trying to calculate the length of intersecting trail that runs through a feature using arcade so that a popup can be calculated on the fly. The value I'm returning seems incorrect and I'm struggling to fix it. For example, a feature that has ~1.1 miles of trail intersecting returns a value of 3.3 miles. The code may be returning the entire length of the trail, regardless of how much intersects the feature. If this is the case, how can I calculate the length of the trail that actually intersects the feature?
// Access the Trails layer by name
var trailsLayer = FeatureSetByName($map, "Trails");
// Find intersecting trails within the selected feature
var intersectingTrails = Intersects(trailsLayer, $feature);
//Calculate length of intersecting trails
var totalLength = Length(intersectingTrails, "miles")
// Return the total length in the desired units (e.g., meters or miles)
if (totalLength == 0) {
    return "There are no public trails on this property.";
} else {
    return Round(totalLength, 2) + " miles";
 Thanks in advance for your help!
JChilders
Changing Length() to LengthGeodetic() solved the issue. My guess is that the two datasets are in different coordinate systems and that was causing the error.
JChilders
