Altering pop-up dimensions
439
01-26-2022 05:21 AM
SimonCrutchley
I was wondering whether it is possible to alter the dimensions of the pop-up boxes that appear in maps. I've looked at the configuration options, but these all seem to relate to material inside the pop-up, not the frame. Is it possible to alter this anywhere else e.g. in the CSS or in the code in JSON?
I ask because in the pop-ups I have a thumbnail and various fields, and at present the pop-up is just too small and necessitates scrolling, something I'd rather avoid from an accessibility point of view.
Kanin
by Esri Contributor
Hello Simon,
Are you using Map Viewer, or will you be creating a web app such as ArcGIS Dashboards? This is because ArcGIS Dashboards has the "Detail"element which is essentially a sidebar that can display pop-up window that takes up the height of the screen.
https://doc.arcgis.com/en/dashboards/get-started/details.htmhttps://doc.arcgis.com/en/dashboards/get-started/details.htm
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
SimonCrutchley
Hi Kanin,
I'm using an app built in Web AppBuilder, but I can't see anything in there that helps.
Cheers
Simon
SimonCrutchley
Sorry, but that is not the solution; I merely stated where I'm working, and specified that I can't find a solution there, hence my question.
SimonCrutchley
Kanin,
Will you please stop marking this as a solution, as it is not a solution. If you mark it as a solution, no-one else will read it and actually offer a solution that might help. thank you. This may work in 'Dashboards', but as I've said I'm working in Web AppBuilder, where I don't see a solution.
