Add surface information - only positive values calculated
228
01-24-2023 07:22 PM
KedaravindanBhaskar
I am using the Add surface information tool to calculate Avg_Slope (average slope) along a 300m line but the tool is only returning positive values. I would like negative values as well.
A similar problem has been reported on StackExchange but it is not yet fully solved. This is the link for the query. I have all licenses for ArcGIS pro and I am using v3.0.0
I have attached photos of the attribute table and dialog box below. Please let me know if you need anything else to assist me.
Thanks!
As you can see for SlopeW all values are positive. I have sorted the bield in ascending order to display the issue more clearlyAs you can see for SlopeW all values are positive. I have sorted the bield in ascending order to display the issue more clearlyThese are the parameters I am usingThese are the parameters I am using
