Update AGOL Content Name and Share
819
10-15-2021 04:19 AM
StuartMoore
Occasional Contributor III
is it possible to change the title of a file thats stored in AGOL and share it with a group using AGOL Notebooks so that i can have it running as a task
thanks
Stu
StuartMoore
so i tried this to share my content
fc_item = search_for_batch_reports[0]
fc_item.share(groups=['5edd............e68'])
but all i get is this:
TypeError                                 Traceback (most recent call last)
<ipython-input-61-44a9c5ed5fef> in <module>
      1 fc_item = search_for_batch_reports[0]
----> 2 fc_item.share(groups=['5edd............e68'])
TypeError: 'dict' object is not callable
by Anonymous User
Not applicable
Hi Stuart, it appears your syntax is correct from what you've shown. See below for a working example. Is it possible your 'fc_item' variable isn't a valid item? What is 'search_for_batch_reports[0]'?
Regarding changing the title of an item, see the below code. Also see the relevant documentation here (note: it appears the example given here is broken - you cannot pass description, title, etc. as arguments. They must be inside a keyvalue pair dictionary):  https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html#arcgis.gis.Item.update
LMK if you have any more questions.
Josh
StuartMoore
thanks @Anonymous User i tried that but got a slightly different error, is it because i am trying to share a Survey123 word document with a group rather than feature
search_for_batch_reports = gis.content.search("H..............1")
print("Search result: ", search_for_batch_reports)
search_for_batch_reports.share(groups=['5edd............e68'])
AttributeError                            Traceback (most recent call last)
<ipython-input-4-1e3c6c4eb4e2> in <module>
----> 1 search_for_batch_reports.share(groups=['5e.............e68'])
AttributeError: 'list' object has no attribute 'share'
StuartMoore
just noticed that in your example you used
 gis.content.get but when i use that it returns nothing but gis.content.search returns my file...
StuartMoore
got the sharing to work using this:
gis.content.share_items(items=search_for_batch_reports, groups=['5e................e68'])
