call/run another notebook
1475
6
09-09-2021 12:46 AM
StuartMoore
Occasional Contributor III
i'm very new to notebooks but i have two questions that i couldn't find an answer for in the community
is it possible to call/run a notebook from a webhook, ie survey completed in Survey123 initiates the notebook?
and my second question is it possible to call/run another Notebook at the end of Notebook (ie running Notebook A but run Notebook B to create some data etc)
thanks
Stu
StuartMoore
thanks for the reply i'll have a play
shikhar_deep
Hi @StuartMoore,
Thank you for your interest in ArcGIS Notebooks. The current released version of ArcGIS Enterprise (10.9) do not support executing a notebook from webhooks. We are actively actively working on adding support for this in near future.
Although, you can call a notebook from another notebook using execute_notebook operation available in ArcGIS API for Python:
https://developers.arcgis.com/python/api-reference/arcgis.gis.nb.html?highlight=execute_notebook#arc...).
Also, please ensure the version of ArcGIS API for Python used in notebook has support for this operation.
Thanks & Regards
Shikhar Deep
StuartMoore
thanks @shikhar_deep i've had a play but can't seem to get it to work, it wont even find the notebookmanager maybe its not implimented in Notebooks in ArcGIS Online
shikhar_deep
Hi @StuartMoore  if you may try the following.
Thanks
Shikhar Deep
DougZietz1
New Contributor III
Shikhar,
From the documentation, this looks like this is an Enterprise only method because one needs to get access to the notebook server. Am I interpreting that correctly?
If not, how could I run a notebook from a notebook on AGOL?
Thank you
DISIG
New Contributor III
Hello everybody,
working in Agol and trying to execute a notebook
is it the correct syntax?
i have an error message but the myItem var is a arcgis.gis.ItemDISIG_1-1670314672035.png
