Regarding giving restrictions (oneway) when building road network
219
06-04-2024 10:43 AM
mohanalogakrishnan
This post is similar to that of
Network Analyst Vehicle Routing Problem One Way Streets
I have a road layer with a field called Oneway ('B' - both ways, 'F' - as digitised (From-To), and  'N'- None). I am building road network layer and including restrictions in the travel directions. Therefore, I would like to use the existing script.
ORIGINAL SCRIPT
      Streets (From-To): Field -
          Prelogic:
            restricted = False
            Select Case UCase([Oneway])
              Case "N", "TF", "T": restricted = True
            End Select
          Expression: restricted
      Streets (To-From): Field -
          Prelogic:
            restricted = False
              Case "N", "FT", "F": restricted = True
            End Select
Since, I have only one direction. Could you please confirm the following script is correct:
          Prelogic:
            restricted = False
              Case "N",  "F": restricted = False
            End Select
          Prelogic:
            restricted = False
              Case "N", "F": restricted = True
            End Select
I appreciate your help on this matter. Thank you for your time.
JaySandhu
The script looks ok. I would suggest that you go ahead and use it, build the network and then add it to Pro and use the Explore tool to check the network cost/restriction values and make sure they are what you need them to be. More details on Explore Network here:
Explore Network—ArcGIS Pro | Documentation
Jay
JaySandhu
Jay
