Network Dataset only opens in Read-only
211
06-06-2024 03:04 PM
Amarz
Occasional Contributor II
Last week I built a network dataset on my testing server and it worked well and I like the results.
Now I am attempting to rebuild it on my production server but encounter an issue where it will only open in read-only mode. I just want to review some of the scripts in restrictions / hierarchy that I set but am unable to open them to inspect.
I have verified there are no locks, or connections, attempting to close and reopen ArcPro, restarted my computer, and even tried to old soft reset of renaming the folder Esri_OLD.
Any ideas as to why this is occurring?
ArcPro 3.2
Dataset version of 10.1
JaySandhu
Have you checked if you have a read only file share? Or you can try to copy it to another location and see if that works?
Jay Sandhu
Amarz
It is within an sde, but I have removed any locks or connections to it and it persist. It is on a dev server that only I have access to and no services are running off it.. So I am hesitant to relocate it.
