What I would like to do is take routes that we already have designed as a feature layer in ArcGIS Pro and convert them to routes that I can use in Navigator. I see the Create Routes (Linear Referencing) geoprocessing tool in Pro, but I'm not sure how to get these routes published to ArcGIS Online as something that Navigator will recognize as a route and can use for turn-by-turn navigation.
Any help is appreciated.
Matt
Hi Matt,
Here is a blog post with a workflow you can try that will help you convert polylines into routes that can be used in Navigator:
https://community.esri.com/t5/arcgis-navigator-blog/transforming-polylines-into-route-layers-tutoria...
I hope that helps!
Chris
Hi Matt,
I hope that helps!
Chris
This is exactly what I was looking for! Thank you.
