Blending Windows ArcGIS Monitor Server with Linux ArcGIS Monitor Agents
117
12-12-2024 07:49 AM
SteveMcCarthy
We are currently using Windows ArcGIS Monitor Server and Agents.  We will be supporting a new team that is all Linux.
Can Windows Monitor Server consume information from Linux Monitor Agents?
DerekLaw
Esri Esteemed Contributor
Hi @SteveMcCarthy,
Yes, you can use ArcGIS Monitor Server on Windows and register ArcGIS Monitor Agents running on Linux with it. This deployment should work fine.
Hope this helps,
SteveMcCarthy
Thank you for the confirmation and that was the answer I wanted to hear.
