Ideally we could get an alert based on the status of a service. A service can be Started, Starting, Stopping or Stopped. Sometimes services can be stuck in a Starting status when a server has been restarted. Knowing which service is still in this intermediary state would be helpful.
Bonus points if we could compare real time state to configured state.
Hi @AndrewSakowicz - We had a discussion about this at the Dev Summit. Can you provide some input on how someone might use Monitor to identify this state?
Might be a solution in an upcoming version.
ArcGIS Monitor 2023.3 will introduce a new "disconnected" or "unreachable" status. This will be tracked in a new metric in which alert rules can be configured on.
