Spatial Attributes for S-57
776
10-12-2022 10:33 PM
CBBiong
New Contributor III
Currently working in ArcGIS Pro 3.0
Where do I find the spatial attributes like QUAPOS for S-57 objects? I can't seem to find it in the ENC schema.
Thanks in advance!
Tags (3)
2 Solutions
Paulakark
Hello @CBBiong,
ArcGIS Maritime stores this information as line features in the PLTS_SpatialAttributeL feature class in the Nautical feature dataset.
Paulina
CraigTGreene
A little bit more information on this.
For points, QUAPOS is an attribute on the feature itself,.
For lines and polygons, as Paulina mentions above, you create a feature in the PLTS_SpatialAttributesL feature class. You digitize the feature as a shared edge along the segment of line or polygon that you want to apply QUAPOS, and then populate the attribute in the PTLS_SpatialAttributesL feature.
I have created a task in our queue to create help documentation for this in ArcGIS Pro. Thanks!
Paulakark
Hello @CBBiong,
Paulina
CraigTGreene
DBrocato
@CraigTGreene Has the documentation you mentioned here been posted anywhere?
CBBiong
New Contributor III
@Paulakark @CraigTGreene Hi guys! Thank you so much for replying 🙂 Cheers!
