Exporting GDB to S-57 error
536
05-29-2024 01:09 AM
CBBiong
If I use the Export Geodatabase to S-57 tool for an "unfinished product" but I wasn't able to check the Sample Export box. Is there a way to reject or remove the export record made? Because I believe I won't be able to export as a new dataset again because of it.
PaulinaKarkauskaite
Hello @CBBiong ,
You can remove the export by deleting the row in the ProductExports table.
Can you elaborate on your issue with the Sample Export? Was the option greyed out for you?
Thank you,
Paulina
CBBiong
Hi, we tried deleting the row before I posted this, but it still does not export properly even after that. Do we need to do anything else after deleting it?
As for the Sample export, it was not greyed out, the user just forgot to check it.
PaulinaKarkauskaite
Hi @CBBiong ,
What error message are you getting after deleting the row and trying to export? If the message tells you that the product is cancelled, check the edition number for the product in the ProductDefinitions table. Deleting an export automatically rolls back the edition number; if the edition number is 0 for your product, update it to 1 and try to export again.
Let me know if that solves your issue.
Paulina
